Hello!
I finished testing my new stereo in my roadster. It worked perfect. I was going to finish the fitting, and had do disconnect the amplifier (Focal Solid 2) and cut the powercable (Battery +). After reconnecting, the fuse on the amp kicked in. I had done a bad connection. The cable from the battery (+) was in the ground on the amp, and ground from car into batteryinput on amp. I did a correction, but everytime I try to give it power, the fuse says goodbye. There has do be something wrong with the amp, or something wrong with the cables, or maybe something wrong with the spot i chose for ground (though it worked fine before the bad connection). The amp is in the forward trunk, and the ground is on the right side (where i found some other cables, but I was wondering if i should test the ground closer to the battery. Any hints?
