Hi I'm looking for anyone thats fitted the standard tweeters. Did it make a noticable difference?
451 Tweeter upgrade any good?
Re: 451 Tweeter upgrade any good?
Admitidly I don't have OEM tweeters at they are just to expensive. I got a £2 or £3 pair from fleabay and they work a treat. I wouldn't go for the official bass bin as it's very underpowered from what I've been told. Your best bet is to get a low profile sub and mount it behind the seat.
Hi,Originally posted by imac331731 View PostAdmitidly I don't have OEM tweeters at they are just to expensive. I got a £2 or £3 pair from fleabay and they work a treat. I wouldn't go for the official bass bin as it's very underpowered from what I've been told. Your best bet is to get a low profile sub and mount it behind the seat.
I am thinking of upgrading the tweeters with non oem ones (for price reasons).
Since you have done this I have some questions...
1. Do the ones you bought have frequency filters built into them?
2. Did you have a job fitting them?
3. How did you fix them, under the factory grills or above the dash?
4. Did you install them without removing the dashboard?
Thanks for any help
Paul
Sent from my HTC Sensation XE with Beats Audio Z715e using Tapatalk 2
Hi,Originally posted by paulodell View PostHi,
Thanks for any help
Paul
1. Wouldn't have a clue :-\ sorry
2. The drivers side is easy as there's nothing in the way, the other side though you ideally need to lower the SAM unit to access the plug.
3. I chased the cables up to the top od the dash so they sit at the start of the bomerang bits on the trim of the dash.
4. You can fit both OEM and aftermarket ones without removing the dash thankfully. The drivers side cable is almost in plain view from underneath but the other side on both the Smarts I've had has been buried in the main wiring loom so you'll need to drop the SAM and look for a small grey or brown plug, untape it then tap into the wire and you're pretty much done.
What about going for a set of aftermarket tweeters (they will definitely sound far better than the stock tweeters)
something like these maybe?
CAS is a leading UK retailer of car audio and vehicle security systems, offering stereos, speakers, dash cams, alarms, and professional installation services to enhance in-car entertainment and safety.
they would have the crossover supplied and just need to be tapped of a source.
as above...don't bother with the factory subwoofer, it's a tiny driver and it's quite frankly an insult to charge money for it!
an aftermarket solution will see you get more for you money and i'd highly recommend the offerings from pioneer.
TS-WX110A, TS-WX210A or TS-WX110A
as far as installation is concerned, you might be better off placing them ON the dash both angled to the centre. This will give you more of a spacial feel rather than relying on the tweeters loading of the front windscreen as the factory system does.
Nice find those tweeters are just the look i was going for also. I ordered those so will let you know how I get on...Originally posted by NeilP View PostWhat about going for a set of aftermarket tweeters (they will definitely sound far better than the stock tweeters)
Paul
Definitely worth it, I have the touchscreen highline stereo and just door speakers, with these tweeters in I can hear sounds that I never knew existed!Originally posted by imac331731 View PostMakes a massive difference.
Love them
Paul
Well yes aventually, the next step is to get some 4 way door speakers fitted, then I might put some more tweeters in the back and then I want a double 12 sub (quick removable so I can still go shopping ha)Originally posted by NeilP View Postgreat to hear!
planning on upgrading the sub department?
Paul
Yes I removed the door skins, its a 451, I used evolutions website guide and wasn't too hard at all.Originally posted by Adamsmart84 View PostDid you install doors speakers by removing skins? What speakers have you used and is there enough clearance for windows?
Those are edge ed 206's they are 5.7in deep and fit fine, window clearance is fine too.
Paul
