I understand that this version of the Roadster has the so-called improved sound package installed, which includes a separate amplifier and upgraded speakers. Does anyone know more about this? And what is the difference between this the normal audio system?
Roadster Brabus Xclusive Audio
Re: Roadster Brabus Xclusive Audio
I have this option installed in my Roadster Coupe (RCR101).
The kit consists of a 240W amp, a subwoofer in the passenger legroom,
new tweeters in the A-pillars, and new door speakers.
It uses the original stereo (or any aftermarket) as input (ISO-connected).
Note: The sub enclosure is molded to fit in the passenger legroom of a LH car.
Will not fit in a RH car. The kit is rather expensive as most Brabus options.
Bjorn
BBE - that only applied to the LHD model.
On UK RHD roadsters there is no sub or amp.
You get mid-range speakers, tweeters under the windscreen, and the crossover in the headunit is activated. On a standard car, the crossover is switched off, and there are no tweeters - full range speakers are fitted in the doors.
The "sound pack" sounds OK (a significant improvement on the standrd audio) but you really do need a sub to make it sound good - most people go for a small active sub and mount it in the recess behind the passenger seat.
You are talking about the standard "sound pack" which is the same in any roadster that has it installed, regardless if it is RH or LH drive.
The Brabus kit is different in every detail, and is LHD only due to the sub.
Bjorn
Bjorn, the Brabus sound upgrade was not available in the UK as it doesn't fit RHD cars.
Hence why I answered the OP's question talking about the Sound Pack - as that's standard fit on the Brabus models.
