Hi All,
I previously had an 09 451 Pulse which I retrofitted the factory Bluetooth hands free kit to (The one that replaces the clock pod) Part A4519062600. It was a simple plug and play although i had to give up the MP3 connection in the glovebox for it to work.
I have just changed to a 2012 CDI with the basic single DIN headunit in it, i thought the bluetooth kit would plug straight in as the same connections are on the back of the headunit but there is no power going to the bluetooth unit.
The instructions when i received the unit were very vague and there seems to be little information on the net about the unit, does anyone know if it will work or can be modified to work with the newer headunit.
Chris
Chris
