451 Rear Speaker locations and wiring?
  • 451 Rear Speaker locations and wiring?
    Hi I have a 451 Passion Cdi, it has the factory standard Pioneer U310Bt stereo radio CD Satnav unit, but with only the two door speakers, up front. I have looked at the unit and it has fader control for back speakers. Am thinking of fitting two back speakers.
    A few questions....
    Where does back speakers normally go, and is it pre-wired to there and connected back at the head unit already?
    Do you also know Ohmic value and wattage of speakers, assuming same as the front ones?
    Any advice would be helpful, before I start ripping bits apart
    Re: 451 Rear Speaker locations and wiring?
    The Pioneer is a generic unit so it will have front and rear even though the smart didn't have rear speakers until the facelift in late 2010 with the introduction of the Highline and lowline stereo.
    The wiring won't be there.
    The facelift had speakers in the boot side plastic trims but they sounded poor and could only fit small speakers.
    4ohms, just like the front.
    If you are fitting new rear speakers (consider the boot hatch trim) then fit better front speakers too.
      Many thanks for that info.
