I have just been looking through the WIS system and came across the Smart procedure for opening a stuck door bar. They even tell you how to make a special tool to free the door using a piece of welding wire and a small block of wood.
I just thought I would post up the document number here as a pointer for anyone who has this issue as the last thing you want to do if you have this problem is try and search for the document in the WIS system. Obviously I can't post the document up as it is copyright
Document number: AR72.10-P-2504CR
