Review: Wynns 'Super Charge' for oil
  • #16
    Re: Review: Wynns 'Super Charge' for oil
    Compression test is fine and you are using oil - question you need to ask then - where is it going, and will additives / thicker oils resolve the issue?
    • #17
      That's what I'm gonna find out...
      • #18
        that was my point. his engine isn't using excessive oil. only what it is meant to in the design specs.
        • #19
          Well it is really using more oil than it should, I've recently put a litre of mobil1 in over about 500 miles, which is over spec.
          • #20
            Just an update on this, it seems to be working, the oil is still going down, but at a considerably reduced rate, I have just had to top it up, but that's due to the fact it was only on about 1/4 when I added the wynns to the car.
            Overall the engine is running smoother, and seems to have a bit more pep, I can't believe it'll do any harm adding this if your engine uses up oil at an over-spec rate, it should help prolong the life of the engine, just as if any 'high-mileage' oil was used in it. It's turbo-charger safe, so I'd say if you're concerned about your oil usage, it's only £4.99 so what have you got to lose?
            (usual disclaimer about things blowing up, engines exploding etc applies).
            • #21
              Hi there has anyone tried this?
              AMETECH ENGINE RESTORE OIL
              Found on ebay any experiences will be good to hear? http://cgi.ebay.co.uk/ws/eBayISAPI.d...3446&rd=1&rd=1
