Moisture around throttle body
  • Moisture around throttle body
    I went to check my oil today (found it to be below minimum!!!)
    Anyway, I noticed that the throttle body intake and around the jubilee clip that holds the hose on is very wet.
    Anything to worry about?
    Re: Moisture around throttle body
    just oil I bet, not sure if its bad or not but mine has the same.
      is it wet type water, or oil? If it's wet, it's probably condensation.
        What other type of water is there??? haha
          Well, you can have dry ice!
            Worth checking the breathers?
              change the throttle body inlet seal if it is oil, oh and check 1 of the four end parts isn't folded in on itself, if a standard smart style induction hose.
                Is that not just one of the crappest designs ever!
