when i increase speed,theres a whooshing sound that comes from the engine ,it dissappears when the next gear engages ,should i beconcerned?
whoosh sounds? PLEASE HELP
Re: whoosh sounds? PLEASE HELP
Turbo noise? Induction noise? Wastegate noise?
Depends on how loud the noise is!
May just be the "chirrup" you hear or the air being sucked in through the filter (do you have an aftermarket/performance filter) - in which case nothing to worry about.
May be the sound of worn bearings in the turbo - in which case you need to get it looked at ASAP!
