I have two knackered outside temperature gauge sensors. Has anyone replaced the thermistor on these? There is a small NTC bead thermistor inside sensor housing. Looking for thermistor spec. One can of course record temperature resistance readings by measuring on a good sensor, then use the Steinhart-Hart equation to work out the thermistor's characteristics. Not that easy when both my sensors have expired.
The sensor is opened out simply by immersion in piping hot water and pulling apart.
