Hello all!
Having trouble with a newly acquired Smart (Pulse Soft Tip Semi Auto 599cc) - I bought the car with problems and decided to undertake the repairs myself - although I have been successful just a bit stumped as what to try next. Never owned a Smart or even driven one so everything is new to me but overall I think in not far off just need some more input/ideas.
Ok so heres the timeline:
Previous owner mentioned car had been sat in storage and battery died, Recharged battery and 3 lines appeared on dash.
Unable to start car/select gear.
Bought car - got it home and began looking online for common faults/problems. Checked wires/gear position sensor/gear select motor/clutch actuator.
All looked OK and seemed to test OK on multimeter.
Ripped both seats out to further trace wires and came across a box (Engine electrical centre) under pass seat. Found corroded wires/snapped pins from water damage!
Replacement Engine Electrical Centre fitted - success!! Can get the car to start and run (wheels in air) and can go up and down the gears.
However I can only get the car to display N on the dash (to allow me to start it etc) if I do one of the following:
(1) Disconnect the battery for a few seconds and reconnect (Car then primes fuel pump, lots of noises, clutch actuator and gear selector sound like they're moving) and the dash will display N and I can start the car and operate it as per normal.
(2) Or I disconnect the plug to the clutch actutator itself and the car will display N on the dash and allow me to start (obviously wont let me change gear etc but will start).
If I do step 1 the car behaves fine until I turn it off and try to restart it. It will then display N in the dash but it will flash N and not stay on, at the same time the clutch actuator starts moving back and forth slightly as if its trying to locate home? and will keep moving back and forth until I turn the key off or disconnect the battery.
Again I disconnect battery (10 secs) turn key, N displays (solid) start car, can go up and down 1-6 and R no problem.
Anyone have any idea? I get the impression that either the clutch actuator is trying to relocate a home spot or that it isn't aware I've turned the car off and it still thinks its running/on? Stuck relay? A broken wire elsewhere? Clutch actutator worn out?
Any ideas would be great! Thank you!
