Fuel pump relay bypass
  • Fuel pump relay bypass
    Hi there as above has anyone got any info on doing the fuel pump relay bypass mod on a fortwo petrol engine,any info would be great
    cheers steve
    Ask on Clubsmartcar. Burning out SAM connector that supplies fuel pump seems to be far too common in Canada.
    PS. Lucky mine has no SAM to burn out. Older 450 Smarts like mine have ZEE with separate relay box under seat and most relays are user replaceable. Much more reliable in my humble opinion.
      A CDI (only) thing?
        Originally posted by Thrumbleux View Post
        A CDI (only) thing?
        Yes, seems to be a Cdi cold area thing. I suppose pump draws too high current when attempting to shift diesel fuel that has turned into porridge due to subzero temperature.
          Cheers TK, and something of a relief to this owner of a petrol engined 450.
          Remarkable though, reading through several threads on this forum, how unsuited to cold climates the CI engine is. Small wonder Grampian Fire Brigade were reluctant to part with their (Rolls Royce) petrol engined appliances. Don't know about GFB, but H&IAA keep their diesel engined appliances in a heated garage with, IIRC, plugged into the mains coolant heaters. What a palaver!
