The engine in my fortwo was rebuilt some 7000 miles ago and they used the composite sump with a rubber gasket but I have found it to be leaking I've tried tightening the bolts which has worked a bit by slowing the leak down but it's still leaking,would I be able to re-use the rubber gasket iff I remove and clean the surfaces or just buy another one,iff so are all the rubber gaskets the same ie for metal and composite sumps
thanks in advance steve
