Thud/Lump when pulling away?
  • Thud/Lump when pulling away?
    Hi all,
    My 03 passion has since I bought it had an annoying thud/lump from the rear when pulling away? If I pull away very very slowly it doesn't happen. I've replaced the single middle, engine mount but it still does it?
    Same thing used to happen in old van I had if you let the clutch up to quickly.
    Engine mounts or clutch?
    I await your thoughts 😊
    Worth checking other mounts and also having a clutch reteach carried out
      Cheers!
      I had the clutch reteached recently and replaced centre engine mount as well and still thuds on take off?
      I have ordered left and right mounts and will post when fitted😊
      Thanks for your help!
        Check the wiring to the clutch actuator where it passes through the intercooler scoop. It is prone to being worn due vibration.
          Finally replaced the left hand mount and although the old mount didn't look to bad the clunk has been reduced to a much lesser thud.
          Have ordered new right hand mount and hopefully will sort it.
          Will post with update later.
