Hi. I have a 2002 City Coupe 600cc. Was driving along fine then auto box decided not to change up. I am able to drive in semi auto mode and it seems to be okay BUT when in Auto it just revs high but will not change gears. [ Occasionally if I decelerate it seems to change up ] Another owner I know suggested it may be the clutch actuator ? Am I able to service this without taking the engine / box apart. Any suggestions please.
City Coupe 2002 Autobox Problem.
Did the search, Did the read. Did the lube. Gears in semi auto seem to shift smoother. BUT still got a problem with Auto the revs still go high but if I reduce the revs momentarily then the box changes up through the gears each time. Do you think I would have to drive for a bit longer for the lube job to take full effect. Any one any further suggestions please.
Did the search, Did the read. Did the lube. Gears in semi auto seem to shift smoother. BUT still got a problem with Auto the revs still go high but if I reduce the revs momentarily then the box changes up through the gears each time. Do you think I would have to drive for a bit longer for the lube job to take full effect. Any one any further suggestions please. PS there are no fault codes coming up on dash just the usual 1 or A
Greetings everyone. Wondering if there is any method to tight my noisy steering rack on my Chevy Epica??? Faced with MS00068 tool from MSG https://servicems.eu/repair-of-power...ring-rack.html Kind of a socket. What is your advice whethere to buy it or not
There are only a few diagnostic systems that will read error codes on a Smart reliably, the MB Star and the WINstar are two of the better systems. Other diagnostic system can give false readings of codes, like my "cheap" bluetooth one which reckoned I had a miss fire on cylinder 5!
Reading your first post it sounds that this is a newly appeared problem. Over the years on these forums, over and over, those with auto mode preferred semi-auto mode because the shift programming was so lousy. Are you sure you have a problem (as opposed to 'they all do that sir')?
Gear change seems to be dependent to engine load. So if you want it to change up you have to take the load off the engine by reducing the throttle slightly. Also it seems to be speed related, I haven't driven in auto for a while, but from memory it won't go into 6th until above 54mph.
I think you just need drive the car more & experiment.
Only the diesel 450 has decent auto function. My Cdi has quick gear changes almost as smooth as silk provided clutch actuator is in good working order and is adjusted correcty mechanically and free wheel pulley is fitted on alternator. Free wheel pulley on alternator allows engine speed to drop faster in preparation for next gear up.
My Cdi accelerating in auto mode about a year and a half ago.
Hi,
I've read somewhere that the ECU learns/adapts to the particular driving style - this box will change up according to a load applied, as already mentioned on here - so if you accelerate gently the shift up will happen sooner, but if you floor it it might get all the way up to 5k revs before it changes the gear. Auto mode on 450 sucks anyway (that's why I have made my own steering wheel shifters), but plugging it into a MB Star and running clutch and transmission adaptation routines wouldn't hurt. If you're anywhere near Gloucester I can do that for a few bottles of good ale
My wife just phoned saying our 2002 Smart 450 will no longer shift up in auto same problem as described in post #1.
I conclude CAN trouble.
The faults were shown as both stored and current but could not be that current since they all disappeared once erased. Auto appeared to work normally when I tested the Smart and before I erased the fault codes.
Obviously without reliable wheel speed data the auto function may not work.
Intend this weekend to inspect main wiring for ABS unit and its connector under the car.
Just noticed, "P0500 vehicle speed. The CAN data are invalid", is also shown as pending. Wonder what that means. I've seen the first two faults for about 10 years and I suspect they care caused by a card fitted under gear shift to allow gear shift using horn buttons on steering wheel.
Last fault is new. Caused by my Polish EGR cheater.
