Smart Fortwo 450 Cooling Fan
  • Smart Fortwo 450 Cooling Fan
    Hi everyone, I have a 2003 Smart Fortwo 700cc, it recently overheated when my wife was driving it. It went to 4 blobs 100 degrees and lost some coolant. I have since found that the coolant tank was split and have replaced it. I have bled the system and all good now apart from the cooling fan doesn’t come on. I’ve read about the SAM but was wondering if there is also a sensor in the cooling system that could be faulty.
    Thanks in advance for any assistance and advice.
    Coolant fan rarely comes on and functioning gauge says temp sender is OK. Relax, enjoy the summer.
      Thanks, enjoy your summer too.
        The temperature sensor is clipped in to the thermostat and can be replaced if you think that is what you want to do. It is possible to put a variable resistor across the two wires that go to the temperature sensor and when adjusted to give the right resistance, the cooling fan will come on.
          Thanks for the info John. Do you know what temp the fan should come on? I thought it would come on before temp gauge went to 4 blobs 100 degrees. I had the temp sensor out when I bled the system after replacing coolant tank.
            4 blobs is a rarity, intervention of the fan rarer still. About three times in my 12 years of 450 ownership.
              Thanks, just was a bit worried in case my car got roasted in the hot weather.
              • Thrumbleux
                Thrumbleux commented
                From memory, a little beyond 4 blobs and the fan will cut in. 4 blobs is rare though and if seen regularly it implies a cooling fault. Even in this current heat wave and driving hard, 3 blobs is the norm.
              I recall we discussed radiator fan cut in temperature not long ago but cannot find the thread. We even did some experiements connecting a variable resistance potentiometer in place of coolant temperature sensor to confirm exactly what temperature radiator fan would cut in.
                Found it over on the other forum:-
                  Post #39 is the relevant one re this thread - fan cut in point slightly above 4 blobs and 100degC.
                  John, did you ever get to the bottom of why no fan at 5 blobs and 120degC? Struggling to believe that 120degC was possible without the system being sealed tighter than a shark's arse at 1000 fathoms.
                    No, but you have to remember that the Smarts temperature gauge only show "blobs" which cover 20 degrees a "blob£ so although my gauge showed 5 blobs, it might only have been just over 100 degrees as I stopped and allowed it to cool and added more water pretty soon after the flashing and beeping!
                    Testing the fan as per that thread, Fan works perfectly. I can only assume I have a very small leak somewhere and the water level got to a point where it allowed an air pocket to form. Which reminds me! Must go and check the water level again!!
                      Thanks everyone for your help, it’s really good getting assistance and information.
                      Happy motoring all.
