Has someone tried or has info on interchangeability of front and rear suspension parts between the 450 and 451?
-Can you bolt a 451 control arm, steering knuckle, strut to the 450? I assume you will need to change the tie rod ends too.
-Can you bolt a 451 rear wishbone on a 450 rear subframe? Is the 451 rear wishbone wider than the 450 one?
If anyone has some info it would be great.
