Can anyone help, please? I have an intermittent fault light on my 2006 smartie. The garage tells me it's come back as a fault with the lateral acceleration sensor and that it shouldn't be driven. Mercedes tell me the part is now obsolete but have given me the part number. Is there anywhere I can find one of these? Ebay has not proved fruitful. Or has my smartie now died?!
YAW rate sensor
You should be able to get one secondhand.
I'm currently trying to decide whether to break my 2005 fortwo for parts. If I do, there is a usable LAS on it.
Before you go full tilt at a replacement, I think there are other things that can lead to a failed LAS diagnosis - them becoming detached and poor connection/broken wire.
- Likes 1
That's good to know - thanks. I'm based in Kent. The local indie garage really didn't want to know after doing the diagnosis - I was literally told that the last time they had to order one of those was in 2016 so they couldn't give me a costing other than smart increase their parts price every 6 months. I'm not sure where else to go?
I don't know what part of Kent your in but Chequered Flag are in Strood http://www.chequeredflaguk.co.uk/index.htm They might be able to help.
That's what I thought too but they were the ones who wouldn't even bother find a price. I'm not sure if they're just over-busy? They also messed up on another car so I'm not sure they are as good as they once were as they used to be so helpful.
Autodoc had two left in stock this morning. Now only one left so obviously this sensor is getting scarce.
- Likes 1
Thank you! For some reason, although I've subscribed to this thread, I'm not getting notifications so have only just picked this up. I've emailed them to double-check as I can't see the part number there that MB gave me. I waited on the chat but then they closed. Fingers crossed it is what I need
Originally posted by tolsen View PostAutodoc had two left in stock this morning. Now only one left so obviously this sensor is getting scarce.
https://www.autodoc.co.uk/bosch/6766...kaAp3xEALw_wcB
Sadly. they said it wasn't compatible
Still looking for ideas!
There are currently several on ebay and cheapest is £22.
- Likes 1
Easiest way to confirm if your yaw sensor is faulty is to replace that sensor with a known good one borrowed from another Smart 450 or Roadster.
The fault could be with the cable. Mechanics are generally rough and exercise little care when working on other peoples cars hence cable damage happens quite often.
Earlier models of the 450 built before 2003 suffer from water getting into the yaw sensor. I have found drying the sensor out and resealing works on the earlier models.
Water could be the problem with yours too. Check under carper under and behind left side seat where sensor is sitting.
- Likes 1
