I've seen two ways to set cam timing for this engine. one way, align cam sprocket alignment marks/lines with top of cylinder head using straight edge, second way align sprocket alignment lines with alignment marks with small timing marks so sprocket alignment lines are under the edge of the head surface. Basically making the second way opposite most all other engine timing procedures. Which is correct....?
Thanking you in advance.
