CDi DPF tech question
    Re: CDi DPF tech question
    Removing the DPF, and the cat... and deleting the EGR (exhaust gas recirculation) you will be fine on a diesel.
    You MPG will be a lot better too.
      Sounds good... Can you tell us more about your replacement exhaust?
        It was very cheap and its not loud. Just unbolted it, cut it open, removed everything, then put a spiral baffle in.
          Any idea how that will effect the tested emissions readings when the dreaded MOT comes around, as questioned by Ian Donkin - will it actually pass, do you reckon?
          My 09 CDi is out of warranty in a couple of days - and I was thinking maybe a remap - but removing that lot sounds a bit severe for me!!
          Mike
            Mike - I now know you can get all the torque you could possibly wish for beyond say 2,200rpm with a remap and the DPF still in situ however I suspect the flow restrictions the DPF and cat cause prevent the turbo from spooling up at lower revs (and therefore keeps the powerband frustratingly narrow). More exploration to come for sure, but my DPF will be remaining for the next 11 months at least for warranty reasons.
            Like you, I'd love to see some numbers on the emissions effect of a decat / DPF removal otherwise the exhaust solution has to invlove keeping the original for one day a year...
              Glad you like the map
              Popped in to see Stuart and Mr Sceptic (Justin) last night
              they are both interested in the out come
              Www.BigPerformance.Co.Uk
              020 328 REMAP (02032873627)
              07702948467
                Loads of companies are now offering DPF removal for smart cdi, Celtic Tuning and others.......
