Anyone else had a recall notice from Smart regarding the possibility of the electronic heater shutoff valve malfunctioning. My car is 2012 84hp turbo model?
Urgent - Safety Recall
Just had a look and there are 2 control valves on the car both attached to the heater unit in the car cabin, one goes onto the in and out pipes and the other goes at the top of the heater unit in the drivers side (right hand drive car), I think it may be the one at the top as the description says electronic valve.
If it's the one we've seen fire damaged, its the one fixed to the gearbox, burns itself to death, scorches the pipes that are attached to it and the wiring, and also takes the command wire out to the starter motor (where there is one fitted!)
Here is the details of recall.....
Description of Defect, how it came to light,and possible consequences if ignored.....
During constant product monitoring, we have found that short circuits in the electronic heater shutoff valve may occur over an
extended period due to wear on your vehicle.
Remedial Action: Rework the electrical line for the heater shutoff valve on your vehicle as a precautionary measure.
Fortwos affected (mainly facelift 451's)......Build Dates 08/10/2010 - 19/05/2014
Originally posted by Evilution View PostThe short circuit is due to rubbing wires, not the actual valve.Originally posted by bbc View PostMine's booked in for fix next week, no parts needed according to the dealer except for a plastic cap and some glue??
