My wife left for work one morning in our 35k 2011 Smart CDi and returned 5 minutes later with steam coming from the exhaust, thinking the worst I checked the coolant level and found it needed a pint or so of water.
A visual check of the engine showed nothing unusual apart from some soot on the outside of the EGR and a couple of drops of water running down the block, my initial thought was a blown head gasket.
As we only bought the car in November as a used approved Smart I called the dealer and got them to collect it as it's still under warranty.
The garage had the car for a few days and called me to let me know that the EGR cooler itself had failed, as the EGR cooler uses the engine coolant it was allowing coolant to run directly into the exhaust, creating the steam.
That's it really, I just thought I'd share this in case anyone else has similar trouble - the car is running fine now, although I have noticed an improvement in MPG which doesn't make sense to me, unless the steam cleaned the EGR/Inlet tract a little.
