I've got a fault on my 451 which sounds like a clutch actuator issue but I can't see what the problem is. There are no codes showing on the ODB scanner.
It's most noticeable when going from a stopped engine in the stop/start situation. As soon as the engine starts and the clutch goes to take up the load there's a thump. It sounds like the clutch is being very aggressively operated initially although it then picks up the drive smoothly after that.
I've taken the actuator apart and cleaned and re-greased it with Lithium spray grease and checked the gear on the motor shaft. Everything seems fine there but the problem persists.
I've moved the actuator through its full travel on the bench and it seems ok. Is there a damper in the system or is it just a strong counterbalance spring in the unit?
The fact that it can still smoothly take up the drive once the clunk has happened makes me think that the encoder on the actuator motor is working as it should. I imagine the ECU would throw a fault code anyway if that wasn't functioning.
Has anyone had this before? I'm really stumped to think what's wrong.
Any help would be very much appreciated.
Roger
Roger
- only $18.95
and your face will
when you see the price.
