Just wondering if this electric crematic heater is on all the 451's Cdi's or only specific dates.
I believe if you turn the heater slider to fully on (max temp), the car will run on the electric heater to give you instant heat for a while, till the hot water heater matrix takes over, is this so?
I find with the heater slider to fully on (max temp) does nothing at all, till the hot water heater matrix heats up, and the heat starts to build up within the cabin,
I have the 451 Passion Cdi 54BHP with DPF filter, Model date....Jan 2010.
Do I have the electric heater or has it just never worked since the day I bought the car secondhand?
Can you physically spot it from under the dash?
