i have a 2009 smart 451 cabrio '
have a problem regards the heat coming out my heater , sometimes its hot , then other times it blows cool .
ive flushed the system &; also checked that there is no airlocks .
i have a turbo gauge fitted which gives me different reading regard the engine & it shows my temperature as 87 which is normal engine temp after engine warms up ..
my independent smart repairer says the thermostat is working ok
myself i would like to change the thermostat as the smart as now done 95 thousand miles & they are known to stick or play up
but thats a last measure as ive been told that the thermostat is in a awkward place & you need to drop the engine ..
the smart has just passed the M.O.T ok , with one first time advisory regards a worn front engine mount which is now done ..
thankyou all .
tony / oldgit
thankyou all .
tony / oldgit
