OK - I've just been out and hooked up my kit to a 56 plate Passion Coupe to re-check so bear in mind that the same may not work on an early car with zee unit or indeed on a 451
1-connect car and star
2-go to "systems"
3-go to engine/meg
4-go to control unit adaptations
5-find the box that starts - Check coding'Activated shift mode after switching on ignition' and double click
6-double click the blue bar on screen with 'coding' at the top
7-select 'automatic shift mode from the options in the drop down box
The rest is up to you!
PS - you won't get it to show without having the car connected! Been there - done that!
PPS - maybe a useful one for Kane to add to Evilution with his usual profession touch added!
2-go to "systems"
3-go to engine/meg
