My Smart fourtwo has been a great car will no problems to shout about but this morning after using the car yesterday when I put key into ignition the key will not turn, Gear leaver is in neutral, Have tried second key and is the same, mhd on a 12 plate with 14300 miles on the clock, any ideas please
Key will not turn in ignition
Sorted after vacuuming and then high air pressure blow gun and more vacuum no joy but plenty of dust muck and sand out of lock I striped it down to basics, Turns out was gear lever was jammed between neutral and reverse and locked so key barrel had a lot of pressure on it, IE no movement at all. knowing this I used a lot more humph than before both on key and lever and all became loose, so after putting all back together it works great and all nice and clean,
Thanks again for replies, davibubb
