I have a 2010 CDI, 75000 miles, It has started occasionally misbehaving as follows.
This is currently happening maybe 1-in-5 times I start:
- Start car (engine hot or cold, makes no obvious difference), hold brake and push gear lever left to put in gear as normal, A on dash as normal.
- Try to move away and it basically dumps the clutch (as in dropping the clutch way too fast in a manual) and the car jolts forwards, sometimes it will stall the engine die to this.
- Re-start the engine and it behaves as normal, on a few occasions I've had to restart a couple of times.
I've also had it do this to me ONCE so far when I came to a stop at a junction with the engine running. re-started and it was OK for the rest of the trip.
Other things to note:
- When stone COLD and behaving normally I get a small amount of clutch judder as it engages, sometimes.
- On some occasions when its changing from say 2nd to 3rd in auto, the engine revs a little higher than I would expect as it engages the clutch.
Could this simply be the actuator needing adjusting to deal with clutch wear? actuator greasing? (Both?) or a sensor issue?
