Where are the jacking points on a Roadie? And what Torque should the wheel nuts be done too?
Jacking points?
Re: Jacking points?
Luke jacking points are in the big owners manual! Would check but my car's still in t' garageOriginally posted by billybugWhere are the jacking points on a Roadie? And what Torque should the wheel nuts be done too?
I do mine tight by hand (as tight as I can get them on) and then check in about 50 miles. Never ever torqued a wheel nut in my life and never had a wheel come off - ever.
Campbellsigpic
DO NOT FEED THE TROLLS
Re: Jacking points?
Unless (for the rear) you are using a scissor jack or trolley jack with small plate at home, where you will find a cutaway/moulding in the door-sill, immediately forward of the hinged flap. See below. The hinged flap can be used (and probably is used by most garages with the larger jack plates on hydraulic lifting platforms). However the flap also serves to conceal the two torx bolts that need removing when you take off the rear wings and rear panel (ie Spark plug/other servicing). Using the hinged flap too frequently may cause the thin plastic hinge to fatigue over time, and split.
The manual also confirms this, "The jacking points can be easily identified by the impressions in the door-sill area".Attached FilesLast edited by c6axe; 26-05-06, 09:12 PM.
