When I went home from work yesterday (wendsday) there was a bad snowstorm getting on its way so I went home a little earlier. Taking it very slow on the motorway (80-100km/h) going upp a hill I wanted to change down to 5th gear, but not the Roadster. It went in to tre horisontal lines and crused to a stop.
I was standing in a very bad place and was afraid that someone should hit the car from the back. I tryed to turn it of but then I could not start it again and the 3 lines came up after it had sounded as somone was fighting in the engine compartment. I got a tow truck there after 2 hours (I was freezing like h**l) and hoping that something would melt and I would be able to start the car again but no. The driver of the tow truck, a very nice man was taking the car all the way into my garage and after an hour or two when I had had the battery of and recharged I turned the key and it said N, I tryed to start and it started. I was under the car today and could not se anything odd. Is it possible to se the levers for the gears anywere?
Today I have driven about 30 km and it is running perfectly.
From now on I will bring a 10 mm spanner everywere I go with that car.
I will be going 70 km to work in the morning!
Jörgen
Jörgen
