ABS light
  • ABS light
    IM having problems with my warning triangle and ABS light coming on when im driving at high speeds (60+) I dont have to be braking for it to come on and it dosent come on at low speed. Its been on the cpu but no faults came up.
    What shoould I check to try to get this resolved?
    Re: ABS light
    Do the ABS and ESP warning lights flash on and then off again, or do they stay on until you next turn off the ignition?
      Re: ABS light
      they stay on
        Re: ABS light
        ESP unit may have gone wrong....... this is very costly £££, hope you under warranty.
        It could be something todo with the brake pedal switch thats gone faulty.
        I had ESP unit problem within 1 hour of owning a roadster, good pdi.LOL but they replaced the whole ESP unit and it never happened again.
        Be very careful driving, you now do not have ABS or Traction control!:wag:
          Re: ABS light
          I think I do, thats the funny thing, I took it for a very fast run last night and it handled great and stopped quickly. Thats the wierd thing it feels no different at all. Im not under warrenty...... Is there anything I can do to try to sort it
            Re: ABS light
            i believe the ESP unit alone is cica £2,000........ hope its not that
              Re: ABS light
              they stay on
              I've had a similar problem where the ABS and ESP warning lights appeared of their own accord, without touching the brakes, while driving along at round 40-50 mph. While the lights are on, you will not have any ABS, ESP or Hill Start Assist, but they will all start working once you restart the car.
              I'm fortunately under warranty and they initially replaced the brake light switch (a common fault I'm led to believe) but this just made the problem even more frequent. On my second visit, they replaced the hydraulic ABS unit and adjusted some tolerance on the brake light switch by 0.5mm and I haven't had the problem since.
              As you're out of warranty, it does sound like it could be an expensive problem... how frequently does it occur?
                Re: ABS light
                Brake light switch was where I was going to look first. Where is it!!??
                I need to try as much as I can myself first coz im getting some custom things done at the min, and thats where my money has gone!!
                So your saying I was doing 120mph (it not big or clever!) with no traction control for over 250 miles!!
                  Re: ABS light
                  brake light switch is under floor - you have to remove the plastic floor panels to access it!
                  I've driven hundreds of thousands of miles without abs, traction control and hill start assist!
                  I'll see your 250 miles and raise it 340,000
                  sigpic
                  DO NOT FEED THE TROLLS
                    Re: ABS light
                    through choice?!!
                    can you be more specific, where abouts inder the car? is it easy to replace?
                    cheers
                      Re: ABS light
                      through choice?!!
                      cheers
                      not through choice - old vehicles had stop and start pedals not much else. Ah the good old days!
                      It is somewhere close to where the brake pedal is but under the car - you have to remove the plastic floor pan - I think you may just have to remove the front part - it is like all things from smart - just clipped on!
                      sigpic
                        Re: ABS light
                        The brake switch is under the floor on a 4-2, but not so on a roadster.
                        If you look up behind the brake pedal you will see it.
                        :silvertri Bjorn
                          Re: ABS light
                          thanks, how will I know if it needs replacing? will it be worn? or do I have to just put another one in?
                          so much to do, so little time, Iv'e just been on taking all the back apart to get the turbo out. Got to removing the crash bar then ran out of light!!
                            Re: ABS light
                            before anyone claims smart unreliability - Ive had a similar problem on two previous NON smart cars (fords), and its always been down to switch gear or ABS failure...
                            Good luck thou
                              Re: ABS light
                              it could simply be a speed sensor on the wheel causing the issue, I would get it plugged into some diagnostics before panicing
