Failed MOT With Central Locking Fault?
  • Failed MOT With Central Locking Fault?
    Anyone else had central locking issues with their roadster? The blimin' MOT inspector failed me today. I need a fix.
    Any help?
    Re: Failed MOT With Central Locking Fault?
    What kind of central locking issue? Whats wrong with it?
      Any help?
      :frown: Nope sorry no help, just hope you get it sorted quick smart
        What does the failsheet say?
          Any help?
          for the central locking?
          What's it not doing ?
            How can it fail on central locking? didn't think it was part of MOT, unless your door catches aren't latching properly
              central locking isnt an mot requirement...nor are doors all together
                They are if they don't let the MOT guy out...
                A driver's or front passenger's door cannot be opened from both inside and outside the vehicle from the relevant control in each case.
                From http://www.motuk.co.uk/manual_620.htm
                  The doors are
                  The doors
                  Latch securely in closed position. Front doors should open from inside and outside the vehicle. Rear doors may need to be opened to gain access to testable items.
                  Presumably the central locking is rendering the doors unopenable?
                    I refer to my previous post
                      Is it the door catch issue? (pin needing relocating to open a door from inside? poss passanger door?)
                        All sorted, the door pin had come adrift and all working again, thx all.
