Miss Fire makes short irregular visits!
  • krassegrand
    replied
    What can I say? Time flies!
    The older You get the faster it flies!
    Jörgen
  • Mr T
    replied
    Only 5 1/2 years to reply... must be a record...lol
  • krassegrand
    replied
    Sorry about the delay.
    I did not write here about the final outcome.
    It was all down to a broken ABS-ring!
    Jörgen
  • krassegrand
    replied
    Re: Miss Fire makes short irregular visits!
    I think You are on to something there!
    I am running the Lilla Svarten on 95 ron. It is the Golden Hornet that runs on E85 (witch is just over 100 ron).
    The Golden Hornet had the odd flicker of the throttle when it was running on 95 ron but is totally symptom free when running on E85.
    I will when time permits test to run Lilla Svarten on 30-40% Ethanol. I cant go to high in ethanol mixture because it does not have any device to enrich the mixture and then it would run to lean on pure E85.
    I have logged for error codes several times. Nothing found!
    Jörgen
  • madDan
    replied
    The fuel when compressed to much can pre detonate before the sparkplug fires, the ECU will manage this with the Knock sensor detecting the pre ignition and adjustment of the timing.
    Thing is I thought you used a high ethanol mix? which was better for this? or maybe I have it backwards???
    It certainly is an odd random fault.
    Also I thought you had logged electrical ignition issues in the error log previously?
    Maybe run it on straight 97/98 RON fuel for a few tanks and see if the problem is still there?
  • krassegrand
    replied
    Now there is a part of the English language I do not understand! Could You please translate to pidgin English?
    Jörgen
  • madDan
    replied
    Maybe the fuel is knocking/pinking and the ECU is not quite catching it?
  • krassegrand
    replied
    This strange missfire/flickering of the throttle is still there. Once this time on the way to work (120km/h on the motorway).
    I think I will just have to make friends with Miss Fire.
    Jörgen
  • krassegrand
    replied
    New (old 45kw) camshaft in Lilla Svarten now.
    Now I have a 60kw engine with 45kw injectors, 45kw turbo and 45kw camshaft.
    Is there any other difference or do I now have a 45kw engine with oil cooler?
    Tomorrow I will go searching for Miss Fire!
    Jörgen
  • krassegrand
    replied
    Thank You Mark!
  • madDan
    replied
    don't forget to drag yourself out from the cars and have a cuppa!
  • krassegrand
    replied
    Originally posted by madDan View Post
    Did they highlight them on the cars inspection there?
    No I talked to Rob at S2smarts.
    It is not a bumb that You can hear it is mor like if You take the foot away from the throttle and put it back on.
    I think this Sunday will be to put the new steering wheel on The Golden Hornet and the Saturday will be a little busy.
    So earlyest in a week I will be able to change cam.
    Jörgen
  • madDan
    replied
  • krassegrand
    replied
    Well then it is a blessing that I have just changed the engine mount on a recommendation from an expert at Smarttimes!
    So now I have 2 fully operational front engine mounts in the garage!
    Jörgen
  • madDan
    replied
    The bump when going off throttle? sounds more like engine mounts to me? rather than anything cam related.
