Hi, hoping someone can help me out.
I am having a problem with my 2004 Smart Roadster. If I disconnect the battery connection and reconnect, the car will start and run perfectly, everything works fine and car will continue to drive fine.
If I switch the engine off and try to restart the car, it refuses to turn over, there is a whir sound (fuel pump prime I assume but no starter). Dashboard lights are normal but I have noticed that the N symbol flickers and I have found that the clutch actuator moves slightly every few seconds.
If I disconnect the battery and reconnect it after a few seconds, the car starts and runs perfectly again!
Thanks for any advice you might be able to give me
Paul
Paul
