Optigear Actuator - any good?
  • Optigear Actuator - any good?
    I've considered having one of these fitted. I understand they improve the gear changes no end. Does anybody here have any experience of them?
    Dave
    Re: Optigear Actuator - any good?
    I had a optigear actuator fitted about 2 years ago, did a wee write up at the time in the Roadster.net guides http://www.theroadster.net/trc/modul...cle.php?id=134
    I've had to have the actuator reset a total of 6 times in the first 16 - 18 months, only did about 9,000 miles, after that it seemed to be ok.
    I still don't think it's a quicker gear change like some people claim, but possibly a wee bit smoother.
    Over the two years and 14,000 (ish) miles of use I'd personally say on balance it's not worth paying the extra, my opinion only, other people will probably disagree.
    JC
      I had a brand new actuator modified by Optigear and incorporated into a rebuild.
      I replaced the clutch and clutch bearing at the same time - none of it necessary but
      there was little sense in a complete rebuild to refit a new clutch within 2 years at most.
      The gearchanges seem a little more consistant and the obvious lags have been moderated,
      but I readily concede that it could be purely subjective.
      I also concede that the new clutch, unmodified actuator and bearing might well have performed as well
      as the optigear set-up which is why I mentioned it.
      If the 'new' actuator ever needs replacing I will probably revert to 'standard' unless I am reasonably flush.
        speaking of actuators were have you all found the cheapest place to buy one from ??
          I went MB - I wasn't aware of any independents stocking them and I wouldn't risk a generic one
          even if they were to be had.
            Isn't Optigear cheaper than the standard one?
            I have had a qoute from the local MB dealer at more than 4000SEK (around €400)
            And I found it at
            for £564.96
            And finaly at
            for just over €200
            Optigear sound cheapest to me!
            If it is also better I know what to choose.
            Jörgen
              Try like for like.
              451 actuator is VERY different to a 450 version
              Www.BigPerformance.Co.Uk
              020 328 REMAP (02032873627)
              07702948467
                451 actuator not a lot of use on a Roady! I
                  Originally posted by Big Performance View Post
                  Try like for like.
                  http://www.smart-stuff.co.uk/smart-f...ator-773-p.asp
                  Oh dear the price was rather different to! I didn't expect that!
                  Still the Optigear is still cheaper! Is it also better?
                  Jörgen
                    I ment it as an example!
                    If I was to buy I would have checked first!
                    Jörgen
                      Dont you have to SUPPLY an actuator AND 200euro?
                      07702948467
                        I suspect that they are just changing the spring, a part that costs them a lot less than €10.
                        They certainly will not discuss what they do to it with potential customers.
                        Cheers!
                          A standard clutch actuator (fortwo 450 and Roadster) from smart retails at about £245 + VAT. I've just picked one up for my fortwo. The invoice is at home so this is off the top of my head!
                          @JamesMackB
                            Don't you have to SUPPLY an actuator AND 200euro?
                            OK I guess You are right!
                            But I would just be playing around with the old one anyway and I think I have heard that You can send in the old one after You have changed it. But maybe £245 + VAT is an option James. Where did You find that?
                            Jörgen
                              From our own test of the actuators we did not experience any noticeable difference from either a brand new modified actuator or a modified refurbished one, the trick seems to be in the spring tension, so the spring pushes the actuator out quicker....but then more force is required to pull it back in!!!!
                              Original MB costs £291 inc vat.
                              www.tune4performance.com
                              ChipTuning - Remapping - Rolling Road
                              Diagnostics - Key Coding - Tan Coding
                              Tel:01923 773002
