Hi all I have a loud rattle vibration in the engine bay its been there for sometime but its getting worse its very mild if you just rev the engine but when you pull off it's loud and in the first few gear changes. Ive had a good look and I've found the heat shield over the turbo is a bit loose but not to bad the only other thing I can find is a hair line crack in the lower mount but again you have to push the exhaust upwards real hard and the crack only opens by 1/4mm so I don't think its that, I cant really find anything else but i'm sure its to do with the exhaust. The only other thing is that the out pipes have always been slightly to the left hand side in the valance and after looking at it pull away the exhaust drops a couple of centimeters, if I put my foot on the out pipes the noise is greatly reduced. I think the can it self is ok. Any ideas?
