i need some help guys ...
  • i need some help guys ...
    i'm buying my first roadster after tons of researches , the car is in mint condition 2005 just 57000 km (the owner works overseas ) but i have 2 problems that i'm concerned of :
    1-when i start to accelerate in first gear (from 0 km/h to like 5-10 km/h) the car is kind of shivering is that normal ? what can help to reduce that shivering effect
    2-i can easily see oil vapor from the turbo charger is it an indicator that the turbo is on its way out ?
    thx,
    Shivering is not normal whatsoever. I would imagine the clutch actuator is badly adjusted or the clutch is worn. Have you read the buyers guide on theroadster.net? http://www.theroadster.net/trc/modul...cle.php?id=162
      Yes It might me be the clutch actuator, thx a lot for the help i just realized it leaks too :/ But should i be concerned about the oil vapor stains that i found?? Thx for the helpp
