Hello guys. I need to buy a engine for a Roadster. The Roadster is 61bhp version and i havê a nice deal for a 82bhp engine. Will it fit?the turbos are equal? I Also have a deal for a 61bhp but it will be beter the 82bhp...
I have fitted a 60kw (82bhp) to both my 45kw (60bhp) cars. One even have a 74kw (100bhp) turbo.
No big problems.
The 82bhp engine has an oil cooler and that is in my view a big advantige over the 61bhp.
The 60kw engine is far superior, not just the oil cooler mentioned earlier but also the stronger pistons which have a bigger wrist pin, the cam is better and injectors are bigger. If you use the 60kw turbo then you will need to use the 60kw exhaust too as it has a bigger flange, Use the 60kw TIK and get it remapped or it will not achieve 60kw.
