Rear Coupe window seals?
  • Rear Coupe window seals?
    Hi all after having to use the Karcher window vac to suck up all the water to see out the windows I've had another good look round and the carpet in the back above the engine bay is saturated I think it may be the rear windows can they be sealed with silicon or is the water coming in some where else? The carpet at the top behind the seats is dry which is a first.
    Thanks in advance
    You can still buy new seals from smart
    Www.BigPerformance.Co.Uk
    020 328 REMAP (02032873627)
    07702948467
      Rear side windows allow water into the boot area via a joint in the Trideon in way of rear top corner of windows. The foam seal is incapable of filling the small crevice hence water gets passed. Just adding a wee bit of mastic in that area is enough to sort it out.
        Tolsen. Your experience on roadster is what ?
        07702948467
          Not a whole lot. My comment is right though for a 450 but may be totally N/A to a Roadster. Still worth checking if that is the cause anyway.
            It's always worth checking which forum a post you are replying to resides within.... so you don't look like a plum!
