Water Pump Pulley
  • Water Pump Pulley
    Hi all,
    Changed the alternator belt this weekend and noticed that the grooves in the water pump pulley are extremely shallow, maybe around 0.5mm deep ?
    I had expected a deep v-groove, like the crank & alternator pulley, and like the new belt profile ?
    Is this normal ?
    The OD of the pulley doesn't look worn at all, as I would have expected the edges of the belt to have worn a recess into the pulley
    I expected it to spit off the new belt, but it's fine ?
    Water pump pully is plain without grooves but belt will over time bed in and make some rather shallow grooves. Nothing to worry about.
      Hi Tolsen,
      Really ? this sounds very odd engineering to me, but if it is normal then I can relax !
      Engine has done 92K miles, so the shallow grooves I see are to be expected then
      Thanks for the insight
