Just bought a Roadster, and I love it. It's huge fun to drive, it looks awesome, but...
When driving around, sometimes the engine just stops without any warning sings. The dashboard clicks, and is lit up like a christmas tree; as if I just switched on the igntion. I can switch to neutral, and start it again right away. No need to wait. (I might have switched off the ignition and back again on some occasions, I am not sure anymore.)
Tried to get some error codes with a bluetooth OBD reader, but no luck. Clean as fresh snow.
I've done some research (partly in this very forum), and I was inclined to believe that it must be the crank sensor. But it doesn't seem to be connected to the engine being warm. Yesterday it did it just after leaving the driveway, it just stopped on the first corner. Then arriving back home after like 30 minutes of driving without any issues around town, pulling up to the gates, and it stopped again. A few days back it just cut out on the top of the Hammersmith flyover, when slowing down, and letting the automatic shift back. If anything, it's only happening at low RPMs. (I am not sure about this, but I might have had a little "pause" on the motorway the other day. Just the dash clicking, but the engine seemed to continue running. It might have push started itself.)
Also the earth cable could be a culprit, I've heard. The one in the engine bay is rather corroded, but I am a bit sceptical about this. It's hard to believe that a cable an inch in diameter could just stop conducting because of some rust.
Just to be on the safe side, I checked the key yesterday, but I can jerk it around as much as I like, the engine is completely fine, so it must be something else.
The only thing remaining is the SAM unit, I am gonna squeeze my head under the dash, and have a look. But then again, it seemed fine when I bought her. Also a blown fuse wouldn't act up like this, it'd completely switch off some parts of the electrics/electronics.
So, anyone any similar experience, tips, insights? Could it be the CPS, despite the thermal invariability? Or should I start with the earth leads? Or is it something completely different?
Thanks in advance.
Thanks in advance.
