I bet a full Brabus spring set from Smart will be cheaper than a set of Eibach springs.
Disappointed with Eibach Pro-kit lowering springs
Smart Stuff sell the Brabus springs for £227.25: https://www.smart-stuff.parts/452-ro...-roadster-7518
A set of Brabus pattern springs made by Suplex can be sourced for £61.04 plus postage.
Originally posted by Goran View PostBuying a set Brabus springs at the Smart dealer will cost me £262. Expensive, but I guess the quality will be satisfactory.
New to smarts?
Originally posted by Thrumbleux View Post
I've had a ForTwo Passion -03 for three years and the Roadster Coupe for 1,5 year. A friend of mine has had three ForTwo and one Roadster Coupe which he drove for many miles in his job, and we have never had a spring failure. But maybe we been lucky, it seems like it is a common failure, reading the url.
Does anyone know which manufactures the springs for Smart? Is the standard and Brabus springs from the same manufacturer?
Maybe you were lucky or maybe at some point smart changed spring suppliers or the manufacturing method. Who knows?! And that's kind of my point. I don't think spring life or quality is an easy thing to predict. Were it not for your desire to lower your car, I'd say just stick with what you have - on the 'if it aint broke - basis.
Given the springs you have (both sets) have, as best as I remember, free tangs - have you considered just cutting them. Lowered and stiffened with one easy angle grinder cut.
It seems like Eibach makes the Brabus springs, see https://mbworld.org/forums/e-class-w...g-springs.html.
That makes sense. Lowering springs are illegal in my country. Even if these eibach doesn't lower the car I think that identifying the eibach brand on the springs will be an issue because the company is stating a 25mm drop with them.
Specs of the eibach springs are listed in their TUV certificate : http://www.dvsegmbh.info/PDF/einbau/...-001-05-22.pdf
My understanding is they are not progressive springs and are close to Brabus specs.
