I've also been working on my welding skills and can say its definitely something everyone should try! Very easy once the welding kit is setup for the type and thickness of the metal .
I know what you mean about welding!!! You just get it right for thick subframe stuff, then have to weld an exhaust, blow hole central!!! Just started using flux core wire (gas-less), very nice results, plus you can work outside.
ps. just did a little sex wee looking at your quaife diff!!
Everythings at the powdercoaters! Here's a before picture..
I'll take an 'after' picture once i get these back early next week.
I've also purchased some bearings to sit on either side of the diff, i'll be bending up the tubing previously purchased and welding together a rough design for the rear subframe.
I love to see projects on here, 6foot4's smart powered by the A series block and Pam Gazeys Smart powered by the Mr2 block.
Keep going people as it's all exciting stuff!!
