hi all.wonder if anyone can help.got a 55 reg cab and am trying to fit some lights in the footwells.have looked at evolutions site regarding connecting onto existing light switch/interior light.my wires are red with green tracer(constant live),black,brown with blue tracer, and brown(earth).what should i connect to so the new lights come on when the door is opened or switch turned on because having tried for the last hour mine seem to come on when switched off and go off when the door is opened
interior lights
Re: interior lights
no worries.i sorted it earlier by tracing the feed to the light in the back.joined some new cable onto existing wires and now i have lights in the footwells.have also put some bullet connectors in the boot area so if i need to work on the engine in the dark i can plug into the circuit.trying to get a wiring diagram to see why original circuit had so many feeds and various voltages
Re: interior lights
i used a lorry marker light eon in my boot area so i can see under my loadcover to get my bag or coat in and out and check the oil wen needed. i wired mine from the interior light above the hatch. really easy and uses low voltage light so no fuse upgrade needed.
