Re: camera
On the upper most part, above the windscreen it just tucks up as there's a 2-3mm gap so nice and tidy there. I ran it to the top drivers side corner, clicking the A pillar plastic off, then down inside of it, the open the drivers door. IT tucks and hides behind the rubber seal so doesn't get trapped and isn't visible.
Then I ran it under the edge of the dash, running it up and over the wiring inside there (cable tie'ing it where required) then ending up popping out under the cigarette lighter and then plugging in.
I will eventually hard wire it to the back of the lighter assembly so it's 100% invisble.
They're a brilliant bit of kit, even for reviewing laps of a track, nice drives through the alps (when I had the Monaro) or playing back moments when people do the stupidist things on the motorway.
Originally posted by fat_rick
View Post
