Hiya all, I am having a little trouble in this area!!
My smart has a sub already fitted under the drivers seat (LHD) and an aftermarket headunit so the sub's RCA cables just connect into the headunit..... the thing is, I am a stickler for standard headunits!
I want to install the standard factory headunit but apparently there are no RCA outputs.
I've been told to use a high-low rca converter but an having trouble trying to work out what I am suposed to be doing!
Am I right in saying all I need is a high to low RCA converter connect it to the rear speaker output cables on the headunit wiring then connect the sub's RCA cables to this little converter box and all done?
Hope that made any sense!!
*shakes head in disapointment!*
