Hi all
When taking the AVIC-F310BT out of my new '10 plate Passion CDI, I noticed there was 4 metres of coiled-up cable between the hands-free microphone and the plug that goes into the head unit! As I was disappointed with the audio clarity of the microphone in its current position (based on comments from the few people I had called so far, in that I had to raise my voice significantly to be understood), I've now moved the microphone such that it pokes out of the trim above my head. The difference is very marked and I can almost talk in a normal voice and be perfectly understood at the other end.
To re-route the wiring neatly, I had to remove the central trim section (with the sun visors), the trim running down the front right pillar, and loosen the trim above the door, but it was definitely worth it!
Cheers
David
PS. A 451 owner for 2 days and already making mods!
Cheers
David
