Can anyone help? I have a 1999 Smart fortwo 599cc, I have recently replaced the original pipe with a Forge silicone one, I have difficulty with the position of some of the hoses are fitted to the new Forge pipe, is there a diagram with instructions available? I have fitted the pipe but engine goes into limp mode as soon as I reach 4000 rpm, I reset by discontecting & reconnecting the battery and all is ok until motor reaches 4000 rpm again, I think I have mixed up hoses causing this problem.
Forge Motorsport TIK Induction pipe fitting
Re: Forge Motorsport TIK Induction pipe fitting
See if theres any new info for you here
Also this if you disconnected pipes further up
The original smart had less pipes and 1 port on the wastegate actuator so you need to look here (scroll to the bottom)
