Help! All brake lights are out!
  • Help! All brake lights are out!
    i have a smart pure and have recently noticed that all my 3 brake lights are out:frown: coincidence??
    however the reverse adnd indicator lights still work!
    any ideas? or is it easier to go straight to the garage?
    Re: Help! All brake lights are out!
    brake switch? http://www.evilution.co.uk/index.php?id=165
      :that::agree::exactly: &
        it must be a 454 or 451 . as 450 or 452 requires the brake swtich to put to reverse.
          There are 2 sides to a 450/452 brake light switch, one for the lights one for the gearbox!
          Kate
            As Kate said, the brake switch is a 2 part design. Both parts don't necessarily die together.
              Just had exactly the same fault!:frown:
              Replaced the switch (£12.33 + vat) & all working again. Easy enough to do, but my electrical connector was a really tight fit so needed to be carefully prised out.
              Don't worry that the new switch looks slightly different & is white, it's just a revised design, I queried this & found it fitted & worked fine. :goodlk:
              Last edited by Mr T; 31-03-09, 07:58 PM. Reason: Price wrong, just looked at recipt.
