Hi everyone,
The slowness of the gearchange on my roadster is starting to get frustrating so I'm going to try and do all the things that might improve it: cleaning the actuator, replacing the gearbox oil, etc.
The only problem is that I can't work out which transmission fluid to use. Evilution lists 7 different types, Fq101.co.uk lists another, and my local Mercedes service centre recommends Castrol Manual BOT328.
I know that a lot of oils are compatible, but my main confusion comes from the fact that I thought Dexron VI fluids were supposed to superceded lower numbers, but no-one has mentioned Dexron VI.
Does anyone know for sure whether it matters which fluid I use out of all the ones I've been recommended?
Thanks for the help!
.......So does that help the PC run more smoothly???
its good when the temperature drops to -30 C..
